Posted by pete 23 on May 07, 2012 at 19:54:43 from (74.32.231.176):
In Reply to: Farmall 460 rear end posted by Dan Osborne on May 07, 2012 at 19:18:06:
It is supposed to be marked with a triangle shape stamped after serial number. Surest way though would be to pull a brake shaft out, check bearing numbers on shaft and look in at the differential carrier bearings. Original were ball bearings on diff and change over was to tapered roller bearings. Brake shaft was still ball bearings but larger and then in a later bearing up date they were changed to a flat bower roller bearing. That was not mandatory as customer assumed reduced price for the bearing pkgs. You could also check part numbers on the differential support housings and inner brake plate.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
