Re: Gear splitter on Farmal H ????????
Posted by gene bender on May 08, 2012 at 03:04:25 from (67.55.226.143):
In Reply to: Gear splitter on Farmal H ???????? posted by John A. on May 07, 2012 at 19:36:48:
It gives you overdrive in gears 1 thru 4 5th is road gear and it does not affect it the od also makes reverse and the pto faster but not belt pulley. In direct drive the speeds are original. Drive it you will like it.
