Re: Need help with a 400D....no go on diesel
Posted by Centex Farmall on May 08, 2012 at 21:24:46 from (166.147.72.27):
In Reply to: Re: Need help with a 400D....no go on diesel posted by sflem849 on May 08, 2012 at 21:00:38:
It has about 1/2 to 3/4 tank of diesel and the fuel has been "on" the whole time so I wouldn't think it would lose prime but I'm in new territory on this one.
Do you have to give it throttle when you switch to diesel or is the linkage designed to give you enough on it's own? We tried moving the lever down some and then switching but no change.
A stuck rack makes sense. Can you get to it under the side cover on the pump?
