Find out first why pressure isn't comming up to normal on the gage. With no blockage or air in fuel line from tank to pump the gage on the pump should come up to normal pressure running on gas. Unless the primary pump on the rear of injection pump has a problem. Sometimes the primary pump drive coupling will fail or other things. You can't be sure the main pump has a problem until the primary fuel supply is working.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
