Re: Farmall m propane problems.
Posted by Centex Farmall on May 09, 2012 at 11:42:12 from (166.147.72.30):
In Reply to: Re: Farmall m propane problems. posted by Andrew Psencik on May 08, 2012 at 20:37:08:
"Back in the day" the mix that made up propane was fairly lenient and running on liquid made sure you burned off heavier elements such as butane. Theoretically if you only ran on vapor you could eventually end up with a quantity of stuff in the tank that would stay liquid in atmospheric temps.
Nowadays I think pretty much all of it is "hd5" which is spec'd to be 95% propane and no more than 5% propylene. In short it's made to me a motor fuel and not gum thing up.
You won't hurt anything by running with both valves open.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
