Re: Lift of belly pump redux...
Posted by mkirsch on May 10, 2012 at 07:54:31 from (64.80.110.74):
In Reply to: Lift of belly pump redux... posted by John Fulton on May 10, 2012 at 04:45:39:
If you look back, the two cylinder version of the Saginaw hitch is widely preferred over the single cylinder. Not only do you get more lifting power (which you probably don't need), but you get more "even" lifting (which is probably not necessary either for typical use).
With a single cylinder, there is some twist imparted in the rockshaft that connects the two sides, during heavy lifting, plowing, etc..
