Re: Lift of belly pump redux...
Posted by M Diesel on May 10, 2012 at 11:45:02 from (12.24.61.12):
In Reply to: Lift of belly pump redux... posted by mkirsch on May 10, 2012 at 07:54:31:
Zactly. They do want to twist the rock shaft with just one. And can if worked hard enough. A pair of 3" (I think) creates enough force to break some lighter implements, like boom poles, and will easily lift loaded rear tires off the ground.
