Re: Lo-Boy runs 10 min's stops
Posted by El Toro on May 11, 2012 at 14:49:10 from (108.3.225.57):
In Reply to: Re: Lo-Boy runs 10 min's stops posted by Co2cub on May 11, 2012 at 14:40:50:
Remove that tube fitting where your fuel line connects the carburetor. It may have a screen
behind that fitting that's plugged. Also when it quits running pull off the plug wire asap before it cools and see if you have fire to the plug. Hal
