Re: Lo-Boy runs 10 min's stops
Posted by Co2cub on May 11, 2012 at 14:40:50 from (173.188.42.126):
In Reply to: Re: Lo-Boy runs 10 min's stops posted by Janicholson on May 11, 2012 at 14:03:44:
Thanks. This Cub Lo-Boy has dual Howard gear reductions and a 6' flail mower. Really want to get out and working. I can be as slow as 1/2mph with the gears engaged. Will check items you suggested. Thank you
