Re: H transmission top shaft bearing and seal
Posted by The Red on May 12, 2012 at 13:44:12 from (69.246.205.0):
In Reply to: H transmission top shaft bearing and seal posted by jbp on May 12, 2012 at 13:03:29:
Been 13 years since I replaced those items but you might want to have a new cage gasket also. The bearing and seal will be in the cage assembly. Unless you have a real early H, that coupler is threaded on so you will want the transmission in gear so you can screw it off. I actually did one with liftall in place. Made for a 3 hour project because there was so little room to work wrenches up in there. The lower countershaft seal and cage flange may be leaking also. Might as well get it all while the liftall is out. Liftall weighs around 100 pounds.
