H transmission top shaft bearing and seal
Posted by jbp on May 12, 2012 at 13:03:29 from (64.57.160.193):
Got to change the top transmission shaft bearing and seal in an H. Anything special to look out for? That pesky lift-all has to be removed first and its darned heavy. I do have a shop jack to use on it though. Joe
