Just be careful reassembling it. I ruined the pilot bearing (which probably needed to be replaced anyway) because I did not have the shaft and pilot bearing lined up. Unless you have someone helping you, you will need to crawl under and out a few times. The thing is heavy, but not like the belly pump--luckily my SM has factory live hyd. I changed all 3 bearings on the top shaft.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
