Timing line on weight retainer inside pump may not be where it should be, is checked on degree plate on pump assembly. White smoke will be worse if all valves in cylinder head are lower than they should be as compression will drop when both valves and seats are ground, best to do a compression test to verify. If tractor starts OK and pulls on dyno OK with timing advanced I would run it. May want to have pump shop recheck advance curve while on engine too. If engine is just rebuilt have seen them get better after running awhile too.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
