Posted by Gil lopes on May 12, 2012 at 17:45:24 from (24.34.239.108):
I have gone completely through this 1206.The pump and injectors have been done and it smokes whiteish when Timed properly at 8 degrees before TDC.If I advance it All it will go it runs better and the smoke almost goes Away.I am unsure as to why it operates this way and How to straighten it out.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
