Get a timing window and put it on to observe automatic advance. It should start to advance at about 1000 rpm and be fully advanced by 2100. Each mark is two degrees on window and it should advance 5 degrees, 2 1/2 marks. Lots of pumps come from pump shops with improper adjusted automatic advance. Don't ask me why but it seems to be a common problem. Also, I found one 361 engine where the timing marks on the flywheel were incorrect. Eight degrees off.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
