power steering squeel/whine
Posted by Dan in Arizona on May 13, 2012 at 06:56:18 from (98.177.231.44):
First off, To all of you out there that take the time and energy to share your expertise and experiences THANK YOU! This is my second post/question. On my Farmall 504 it has the power assist steering under the steering wheel and an oil cooler for it in front of radiator and an after market wide front, no loader. It seems to have a very loud squeel (like air) coming from the cooler area at any rpm however if I turn the steering to the stops the noise seems to go away. I have changed hydraulic oil and filter and filled the oil to 8" below operator platform (higher than check plug). When I put a screwdriver on the 3 way diverter valve (the valve where you can adjust how much oil goes to the steering pump)it sounds kinda like the whine/squeel I hear in the front. 3 pt hitch and draft control all seem to work fine. Seen a post dated 10 July 2010 about PS check/relief valve. I do have the manual for the tractor. Any ideas?
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
