Re: Purchased Rebuilt Carb - H won't Start
Posted by ChrisL on May 13, 2012 at 10:13:14 from (64.222.234.27):
In Reply to: Purchased Rebuilt Carb - H won't Start posted by ChrisL on May 12, 2012 at 11:32:32:
To answer a few of the questions:
Venturi is not missing, yes it ran before and tried with full choke. I thought I was going to burn up the starter.
I will say the original carb was a 45108DD (distillate or Kerosen) the rebuilt is a 50981DC (I did replace the distillate intake/exhaust manifold some years ago with a gas one, but maybe this is the cause.
So I guess I am giving up and sending this nice clean carb back and will do the rebuild myself. The main reason for purchasing a rebuilt was to save some time fixing mine, it has a loose choke lever and is quite gummed up and it leaked (had to put vice grips on the gas line when not running) but save time was not the result.
Thanks everyone it's been a while
