Re: Super A replacement seat problems
Posted by Jim Becker on May 13, 2012 at 15:06:03 from (173.74.120.222):
In Reply to: Super A replacement seat problems posted by Todd in NC on May 13, 2012 at 07:19:20:
The springs should be bolted in the same position on each side. There is usually a fair amount of leeway on exactly where the springs end up because of slack in the bolt holes. You should be able to install everything with the bolts a bit loose. Then slide things around until the seat latch works and tighten the bolts. All parts are identical on A and B seats.
