Re: 574 power steering box (pump)
Posted by Bernard le mecano on May 13, 2012 at 15:52:05 from (75.158.242.6):
In Reply to: 574 power steering box (pump) posted by Yellott Canby on May 07, 2012 at 19:29:06:
Hi, sound like you have a Danfoss orbitrol valve. The shaft come with the bearing and housing as one part.To change the seal if you have a leak, you have to open the orbitrol valve and with a tool replace the new seal in place.Bernard le mecano
