Re: Farmall 300 engine questions
Posted by D Slater on May 13, 2012 at 18:24:16 from (184.15.44.141):
In Reply to: Farmall 300 engine questions posted by Zachary Hoyt on May 13, 2012 at 17:52:39:
If the rollers are locking up like normal in the t/a the engine will only roll one direction unless the t/a handle is pulled back and the t/a clutch releases. Think you have a messed up t/a handle and hard to say what else. Also unless the t/a clutch releases the tractor will only roll in gear if rolled in the same dirrection as the gear selected. Independent pto drive splines to the main clutch pressure plate so if a lock up is in the pto unit or drive it could keep the engine from turning. Some 300 or more than half have the seasonal pto disconnect on the bottom of the t/a housing. If so it can be shifted out and the rear unit and drive isolated from the front drive parts. Also may want to make sure the trans isn't in 2 gears due to messed up shifter or forks. Without a t/a clutch releasing proper some shifters get ruff treatment pulling trans out of gear at times.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
