Re: Farmall 300 engine questions
Posted by mkirsch on May 13, 2012 at 18:38:24 from (67.253.161.186):
In Reply to: Farmall 300 engine questions posted by Zachary Hoyt on May 13, 2012 at 17:52:39:
Zach, don't overthink the engine being stuck. It is probably just simple rust in the cylinder from sitting. Put some ATF in the cylinders and try working it back and forth for a few days.
Clutch is probably stuck to the flywheel from sitting too. Once you get the engine running you can attempt to break it free by driving it around.
From your description, they parked it because it was making the noise. The noise is not what made it stop.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
