Re: Farmall 300 engine questions
Posted by Zachary Hoyt on May 13, 2012 at 19:22:45 from (184.8.248.104):
In Reply to: Re: Farmall 300 engine questions posted by mkirsch on May 13, 2012 at 18:38:24:
Thank you for the advice, I will try the ATF first and see what
happens. I'll put some cardboard underneath so I can see which
cylinders are letting it through. Your last sentence describes the
problem exactly. Once I get it running I will be able to hear the
squeal and try to figure out what is causing it.
Zach
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
