Re: Super H Governor
Posted by pete 23 on May 14, 2012 at 17:40:27 from (74.32.231.176):
In Reply to: Super H Governor posted by TV Iron on May 14, 2012 at 17:15:59:
It is hard to tell from your description of the gov problem weather you changed the cross tube linkage between governor and carburetor before or after your problem developed. If you changed it , and then the problem started you no doubt have missed the alignment notch between carb and gov. If it was present before you changed it and you changed it trying to overcome the problem, well, then the butterfly in carb is loose or missing a screw and not closing. If I was there I could tell in an instant just by looking at the linkage and feeling it with the pin out hooking gov to cross tube .
