JRSutton said: (quoted from post at 09:35:01 05/16/12)If you've ever felt a kick back you'll understand that I have a vested interest in knowing EXACTLY what this thing is doing and that it's set up correctly!
Hey JR - been there, done that! As recently as yesterday in fact cranking up a friend's hand start JD A. (A sudden kickback on a flywheel is not nearly as dangerous as a hand crank.....but it still gets your attention!)
Anyway I suggest this as an additional final step to verify the timing is correctly set:
Attach a timing light to the #1 plug wire. (If your tractor does not have a battery you'll need to supply the timing light from a separate 12 VDC source). Now slowly turn the crank while observing the timing mark. If the mag is timed correctly the timing light will flash at exactly TDC.
I then like to retard the mag 3 or 4 degrees AFTER TDC to prevent kickback while cranking.
Do the timing light test several times (several more revolutions of the crank) to make sure the mag trips consistently 3 - 4 deg after TDC.
The broken wrist you save may be your own!
This post was edited by Bob M at 06:03:54 05/19/12.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
