Posted by jbp on May 16, 2012 at 15:45:41 from (64.57.160.183):
The top shaft seal was leaking because the ball bearing on the transmission input shaft had a lot of play that had worn out the leather seal,also it wore a groove in the input yoke. Got the bearing and seals today, the redi-sleeve for the yoke will be sent UPS to me. The lower shaft bearing and seal is good with no leaks.
The lift-all leak was nothing more than one of the outlet pipes being little more than finger tight. Guess we all should get lucky once in a awhile.
There was a coil spring lying loose in the clutch housing. One end connects to the clutch throwout bearing fork but I have yet to find where the other end connects. There has to be a place somwhere so I'll keep looking. Hope the lift-all goes back as easy as it came out using the shop jack. Joe
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
