Re: Update on transmission and liftall leaks
Posted by pete 23 on May 16, 2012 at 17:54:34 from (74.32.231.176):
In Reply to: Update on transmission and liftall leaks posted by jbp on May 16, 2012 at 15:45:41:
On the H there should be a pin with a hole in the end driven down from the top through the clutch housing (torque tube). For the speedy sleeve, if the groove is deep in the yoke you might want to fill it with liquid steel or the speedy sleeve may wear prematurely.
