Set the mag to fire on #1 TDC and it will work just fine You are either in time or 180 out. Does the rotor line up with the tower on the cap when it fires. Put it in a vice and turn it over watching it snap and mark the location of #1 on the body and you can see the rotor stop at that position when it fires. I fasten them in the vice hook up wires to all plugs then using my batt drill can see all plugs firing at start and running rpms
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
