rrrg - another magneto question.
Posted by JRSutton on May 16, 2012 at 18:16:07 from (75.130.109.233):
third party image
Tried to install the magneto earlier today.
I can get the thing to fire right AT tdc, but that's with the mag already in the fully retarded position.
We did line up the dots on the governor gear/cam/gear/crank gear when putting the engine together.
This is how the tractor used to run - from the original owner - so I'm pretty sure it would run (though it used to kick back often)
So I'm thinking the mag is off somehow.
It's a Wico mag. I've include a picture of the bottom of it.
There are degree markers - and a ring with a V shaped projection (to the right of the 3750 in the picture) that trips the mag.
I'm assuming I can loosen the 4 screws and turn this ring a bit to make the mag trip later in relation to the rotor position - and solve my problem.
Seems kind of obvious - but figured I'd check before I break something.
