If it clicks right at TDC it's FINE. Leave it alone. running it will be slightly advanced. Look at the degree marks. What angle is it set at? I think it should be 35° if it is faster than that (ie 23° or so) moving it will cause the impulse to fire later (LAG behind) in STARTING only. Running timing will not change. If you need to change running time you are going to have to pull the drive out and move the gear a tooth or two.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
