Re: rrrg - another magneto question.
Posted by JRSutton on May 17, 2012 at 08:12:06 from (75.130.109.233):
In Reply to: Re: rrrg - another magneto question. posted by Jim Becker on May 17, 2012 at 07:16:58:
... too early to get excited - but I think I figured out the problem.
If each tic mark is 5 degrees - I'm thinking the orignal owner set this mag counting from the first mark as 5.
5 - 10 - 15 -
Where the pointer is now would be 35 using that method.
Might just be a coicidence, but would explain the problem.
