47 cub wont start help
Posted by casefrank on May 17, 2012 at 20:41:19 from (66.194.11.157):
OK I"m lost here, Just finished putting new ring in her as the old ones we colapased. Had been bored .030 over Did valves too. Has nice blue spark from the mag. Set timming this AM and she Started and ran this AM for a few minutes then ran out of gas. Put new gas in and now will not start, run or stay running. Good engine turn over has 120 psi on the cylinders and 25 lbs oil psi, pulled carb off and cleaned it Had it rebuilt by Motec Eng. a few months ago, found little dirt cleaned everything, and made sure that each opening is open by spraying carb cleaner in each one, and put it back on. Now it hits and misses and puffs black smoke, starts to run but only for 5-10 seconds. Applying the choke doesn"t do any good. Pulled the main jet out and it had good clean fuel in the carb.
Any one know how big the fuel inlet valve hole sould be look alfull small to me. Have goveanor disconnected as it is another challange.
Please tell me it"s some dumb thing I"m doing
Thanks Frank
