Posted by CNKS on May 18, 2012 at 17:11:42 from (216.144.104.128):
In Reply to: Putting TA in 44 H posted by Jay Poole on May 18, 2012 at 08:35:01:
If you put your H engine on a 300-350 rear end, and you use it for tillage, you need to up the HP of the H engine. Reason is the gears in the 300-350 and even in the Super H are different, 4th is 6+ mph and 3rd in the SH-up is only 1/8 MPH slower than the 5 1/8 mph 4th in the H. If you are doing any kind of heavy tillage that leaves you with only one field gear-2nd, 1st being too slow if you ever want to get done. 3rd is considered a field gear in the H (I used it for years), while 4th can only be used for lighter loads, same with 3rd in the 300/350 with the H engine.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
