F-20 head torque
Posted by Al P. on September 25, 2000 at 19:36:18 from (208.153.59.139):
What is the correct Torque for the head on a F-20? I had tightened to 65 ft lbs and am seeing leaks in the water side from the front to the back and allong the manifold side. appears to be on block side only. have retorqued the bolts again as many seemed loose. I have less than ten hours on the rebuild. I did not use any gasket sealer (any recomendations) I suspect it is time to take the head back off and buy a new gasket but am looking for opinions.
Thanks
Al P.
Post A Followup
: Re: F-20 head torque
