Re: F-20 head torque
Posted by Kendall on September 26, 2000 at 06:42:40 from (207.136.51.208):
In Reply to: F-20 head torque posted by Al P. on September 25, 2000 at 19:36:18:
Did you have the head milled when you did your rebuild? If not, have a machine shop check it out and mill it if necessary. This will assure that its flat. Head bolts should always be re-torqued after a few hours of running for the first time. Finding some "loose" is to be expected after a heat up/cool down cycle.
Post A Followup
: Re: Re: F-20 head torque
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
