Re: Farmall 200 hard to start
Posted by Bob M on May 21, 2012 at 12:37:54 from (74.67.189.51):
In Reply to: Farmall 200 hard to start posted by Workman on May 21, 2012 at 11:43:02:
I agree with Jim N and Dean - it sounds like too much choke.
Those Farmall engines generally require little if any choke to start in warm weather. On mine I open the throttle about 1/4 then hit the starter. If the engine doesn't fire in the first couple revolutions, quickly "snap" the choke closed then full open again and they take right off.
Don't crank the engine more than a revolution or two with the choke closed - it will quickly flood as you have discovered!
