Farmall 200 hard to start
Posted by Workman on May 21, 2012 at 11:43:02 from (67.234.145.38):
I rebuilt my farmall 200 and it runs great, but the problem is getting it started. When I crank the tractor over with the choke on fuel runs out the intake side of the carb. Sometimes it will start after this and its fine and other times it won't. All the cylinders have 150psi of compression. I tried advancing the timing. I switched exhaust manifolds, but the problem still remains. I also pulled the carb apart and blew out all the jets. Any suggestions would be greatly appreciated. Thanks.
