Re: Farmall 200 hard to start
Posted by mkirsch on May 21, 2012 at 13:05:25 from (64.80.110.74):
In Reply to: Farmall 200 hard to start posted by Workman on May 21, 2012 at 11:43:02:
Have you tried to start WITHOUT the choke?
Every tractor is a little bit different in what it needs to start easily. You have to find that happy place your tractor wants to be in, and go there each and every time you start it.
You could need anywhere from full choke, to a quick blip, to no choke at all.
It's also possible that you are not getting a good spark while cranking. If your starter motor has problems it will be drawing too much current, and you will not get good spark.
