Re: Farmall 200 hard to start
Posted by JRSutton on May 21, 2012 at 14:12:20 from (75.130.109.233):
In Reply to: Farmall 200 hard to start posted by Workman on May 21, 2012 at 11:43:02:
I'm wondering if the choke has any real impact on the gas dripping, or if that's just a coincidence.
Do you shut the gas off to the carb when not in use?
Typically if the floats are off - it'll start dripping after you open the gas up, but only if you don't get it started right away.
It takes a while to start dripping because the bowl has to fill up full first - and that can take quite a few number of seconds to happen.
As you're starting it - it's drawing gas in, slowing the drip a little more.
Once you've started, it usually sucks in enough gas to keep from dripping.
But if it doesn't start - you'll definitely see it dripping a lot.
What I would do turn the gas off and try starting it. Whether it starts or not doesn't matter - you just want to get most of the gas out.
Let it sit for a while (hour or so just to be sure).
Tturn the gas on for a two seconds, then turn it off. Check the carb, make sure it's not dripping.
Choke as usual - full or 3/4 and try starting it. (even try in and out while starting)
If it doesn't start - open the gas for a little longer to make sure you've got enough in there - then try again.
If it starts that way - you can be pretty sure your floats are off and letting too much gas in. In other words, don't focus on the choke.
