Farmall B Generator question
Posted by luv2wrench on May 21, 2012 at 17:57:27 from (72.107.45.241):
Just got my generator back from being rebuilt. Got new field coil, bearings and bushings, and brush set.
The shop wired the cut off relay terminal GEN to the A post on generator. Post F is blank on the generator body/housing.
I have two wires to hook to the generator that i took off awhile ago and didn't mark. The bigger 10-12 guage wire looks like it goes to the BAT terminal and the smaller wire to the F terminal on the cut out relay??? They "lay" in that direction. I am re wiring the entire tractor because of the orignal harness looks tired.
The B has factory lights front and rear and starter. The tractor also has a mag. Still positive ground.
THANKS FOR YOUR HELP GUYS.
