Famall B valve clearence
Posted by luv2wrench on May 21, 2012 at 18:33:45 from (72.107.45.241):
is the gap .014" HOT? do i just set 1 and 4 TDC and adjust those cylinders and 2 and 3 to TDC and adjust those?
the engine has a miss at times while running. rebuilt carb and mag. still the same but doesn't die like before. The carb float had gas in it.
still flutters but able to mow with it. just a pop pop pop then clears and come right back. have not tested compression or cylinder leakage yet. intake gaskets don't seem to be leaking.
