Re: Re: Super M 50 yr old fluid
Posted by Andy Martin on September 26, 2000 at 08:19:19 from (38.31.74.52):
In Reply to: Re: Super M 50 yr old fluid posted by Bob M on September 25, 2000 at 19:24:47:
When you drain it:
Clear water on the bottom of the transmission is from condensation and should not worry you. It is clear because it is not deep enough to be stirred by the gears. You may get a quart of crystal clear water when the plug is first pulled. A dishonest person can get the price of a tractor down by checking the fluid at the drain in the seller's presence, if water comes out!
Oil should be black. If it is amber (translucent) it is new and you did not need to change it.
If the oil is brown and foamy it has had lots of water and you are glad to be changing it. Bearings are still probably OK because is a Farmall.
Post A Followup
: Re: Re: Re: Super M 50 yr old fluid
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
