Re: No start A Farmall
Posted by old on May 24, 2012 at 20:03:29 from (209.86.226.40):
In Reply to: No start A Farmall posted by Gordoro on May 24, 2012 at 15:37:50:
Ok so you say mag then distributor which do you have hard to help you help your self if you do not know if it is a mag or distributor and they are not the same thing.
