No start A Farmall
Posted by Gordoro on May 24, 2012 at 15:37:50 from (97.95.47.41):
I have a 1945 A Farmall. I used it today, start and shutoff many times. When I finished mower my lawn I shut down, to wash the deck and tractor off. But my hose was not long enough, so I was going to move the tractor closer, it would not fire at all. There is spark from the mag coil, and spart to the plugs, it is getting gas to the carb. I chesked the points set at 13, the dist cap looked very good no buildup and the center button looked good about that center button it moves up and down the rotor also looked good. Now then would a weak or dead condenser cause this? Thanks in advance, I have been away form mechanic work for quite awhile. Gordo.
