Re: No start A Farmall
Posted by Jim Becker on May 25, 2012 at 16:21:41 from (173.74.120.222):
In Reply to: No start A Farmall posted by SDE on May 24, 2012 at 15:37:50:
There is nothing wrong with what you said. The entire portion of the magneto behind the points is called a distributor. The cap with all the secondary wires stuck in it is a distributor cap.
The spark at the plugs should be about as good as the spark at the coil. You appear to have a problem with the cap, rotor or the wires. Make sure you have solid core wires, not resistor wires. I'm not saying this is the cause of your current starting/running problem, but you do want to look into it either now or later.
