Re: Fender Fitting Thwarted; Grrrr…
Posted by SadFarmall on May 27, 2012 at 05:58:08 from (112.213.196.210):
In Reply to: Fender Fitting Thwarted; Grrrr… posted by SadFarmall on May 24, 2012 at 02:27:40:
Thanks for the advice folks! Recoils are in and the fender is attached! As to the punch jammed in the broken bolt there are couple of options. If you have a much harder centre punch, then you might mark it and drill out the remains with a HSS drill or tungsten carbide drill if required. A difficult and slow job… Good Luck.
SadFarmall
