Farmall H Petrol/Gasoline Tank Tap
Posted by SadFarmall on May 27, 2012 at 06:00:55 from (112.213.196.210):
My 1940 Farmall H is set up for kerosene operation. The smaller fuel tank tap leaks severely past the handle shank. I cannot remove the tap from the tank without risk of tearing the tank body because the tap is screwed in so tightly. Is there some sort of packing (similar to water pump packing) I can use to stop the leak? The tap seals off the fuel perfectly well, but drips constantly when open. I do run the tractor on kerosene for heavy work, so I need both tanks. Any advice appreciated. Thanks.
SadFarmall
