Re: Farmall H Petrol/Gasoline Tank Tap
Posted by Jim Becker on May 28, 2012 at 08:51:41 from (173.74.120.222):
In Reply to: Farmall H Petrol/Gasoline Tank Tap posted by formerly ny bill on May 27, 2012 at 06:00:55:
A couple more comments:
1) Some guys use an o-ring. It needs to be fuel-proof material. It will survive being stretched over the inner end of the stem.
2) Most (all?) of the originals valves were back-seating. Those don't need packing but if not completely open, they will leak.
