Thanks Gene, got the timing right better spark at the plugs. But I just can not get gas to the plugs. I even tried to choke it a lot longer but the plugs stay dry. I put about a teaspoon of gas in each cylinder. All I got after a little spinning of the starter was a backfire from the exhaust. I have gas to the carb, I checked this with a hose hooked to the bottom of the carb and one end above the carb it shows the level of gas in the carb about 2/3"s. Gas runs freely from the tank. While spinning the motor over with the starter I put hand over the air cleaner intake above the tractor and have to pull quite hard to remove it. Seems like a lot of suction. Has anyone got any more suggestions? I.m almost getting desperate. Hope I don"t wear out the starter. Must have been rebuilt before I bought it cause it sure works good. Thankfully. Anyway thanks any and all help is sure appreciated. Gordo
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
