Hi, I tried JR Suttons way so far no start. I also took the drain plug out of the bottom of the carb replaced it with a piece of pipe with a clear plastic hose attached. I then raised the hose above the carb. With the gas turned on the level of gas in the carb is about 2/3 full. It will remain that way while running the starter with gas on. Did it that way for a check on the action of the float. Then went back to gas off wait and then try. Still no start. This could get frustrating. Ill try again later. Thanks again Gordoro. Any other suggestions? I am open to anything just to get it running. Thanks.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
