Re: help 650 diesel
Posted by Russ600 on May 27, 2012 at 20:48:50 from (216.238.232.187):
In Reply to: help 650 diesel posted by dAllen158/0 on May 27, 2012 at 18:48:42:
Hi Could be a plugged injector you could try # 3 injector on an injector tester, if you don't have easy access to a testor move the # 3 injector to another cylinder if the miss follows the injector I think it would be an injector problem, if it stays at # 3 cylinder could be a valve or other issue. Good Luck.
Cheers
Russ
